Militarybuilt Posted January 9, 2019 Report Share Posted January 9, 2019 I'm new to this world so don't kill me....... So I acquired another "project" Banshee today. The guy put the engine together with the Hotrods 4mil long rod crank, the cylinders and pistons are out of it so I'm questioning things. I read that it needs to run the Vertex pistons but he has some Wisco's that were made for a long rod crank, will those work? Also, it came with an aluminum spacer/plate under the cylinders, again I'm assuming here, that's so you don't have to mill the domes? I appreciate all the help. Thanks. Quote Link to comment Share on other sites More sharing options...
97Screamer Posted January 9, 2019 Report Share Posted January 9, 2019 A long rod crank requires pistons that have the pins moved also to account for the longer rod. In wiesco long rod pistons are 795 series, not sure about Vertex because no one besides vertex would recommend running them 😁. Spacer plates are, as you said, to avoid having to cut the domes. They also set the lower port to the correct location but make the upper port timings worse. Not to mention the possibility of air leaks. If you want to get proper performance from the engine send the cylinders to get ported for the 4mil crank, buy cut domes, and throw the spacer plate in the garbage. Quote Link to comment Share on other sites More sharing options...
Schweet97Z Posted January 9, 2019 Report Share Posted January 9, 2019 I have new cut domes and 795 pistons. If interested PM me.Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
