i have a question how do you get a 370 with a +4mm stroker? i have a 4mm storker .20 and its a 379.blahblahblah cc's is this a stock bore 4mm? whos doing the porting?
is your builder using the blaster pistons because of the long rod? they now have wiseco 795 pistons in any bore size for the long rod crank. blaster pistons is the old way of doing a longrod.
i have a 4mm stroker long rod, im using the 795 pistons, and a decking plate for the stroker, as well as ported for the stroker.
with blaster pistons, you will be at the least 370cc without the stroker crank, add in the stroke and you will be over 400 i believe.
the stroker is great everywhere.
cool cool good to hear were starting today...i gotta get the piston skirt out of the bottom end first! haha my buddy joe d. (fmf trucker) has a guy thats local whosgonna port my motor and hes workin with a guy that was with procircuit for some odd amount of years so itll be done right... the kid thats doin mine did joe d's dad's 250r and that was done awesome and hauls ass thats a 270 stroker with porting and the works etc. etc ..... you think ill be faster than him? oh yeah Blue Deuce... did you get any dyno charts or horsepower estimates out of your 370?
That's what I was thinking.
i havnt dynoed it........it's roughly 75-85hp depending on your pipe, reeds and carb setup----i would hope it would smoke a 270-----the best part of it is you can feel 30 horses right off idle...........
were boring .040 over to get out those nasty scars, and were doin 5 mm stroker so it turned out to be a 385 cc stroker. im so excited for this and it should be done in less than a month so whoo hoo
