salmon_slayer06 Posted June 15, 2018 Report Posted June 15, 2018 What are the taller riders using. The banshee doesn't feel comfortable and i need to do something about it for handling and safety. The quad has been rolled and the upper frame is tweaked as taking the gas tank off requires a bit of wrestling. So i dont know what to expect or if i can easily fix that issue... thanks Quote
Toybreaker Posted June 15, 2018 Report Posted June 15, 2018 the steering hoop is bent back, muscle lots of it to get it close to right. (I hooked my bike up to a tree and used a come along hooked to my truck to pull that hoop up close to straight.) you can buy a taller stem, buy bars that have a taller handle position or get some bar risers. But keep in my you might need longer cables and/or front brake hose with that mod.... Quote
salmon_slayer06 Posted June 18, 2018 Author Report Posted June 18, 2018 Thanks for the tips. I didn't know i could straighten that out. I have a twist throttle, stock clutch cable and longer front brake lines for the wider arms. Quote
Larry's Shee Posted June 18, 2018 Report Posted June 18, 2018 On 6/15/2018 at 6:51 AM, Toybreaker said: the steering hoop is bent back, muscle lots of it to get it close to right. (I hooked my bike up to a tree and used a come along hooked to my truck to pull that hoop up close to straight.) you can buy a taller stem, buy bars that have a taller handle position or get some bar risers. But keep in my you might need longer cables and/or front brake hose with that mod.... Where did you hook the comealong to. Quote
Toybreaker Posted June 18, 2018 Report Posted June 18, 2018 7 minutes ago, Larry's Shee said: Where did you hook the comealong to. on the frame or truck? on the Banshee frame I looped a tow strap on the top of the hoop, On the truck I hooked it to the pintle hook in the receiver hitch. Hooking it to the tree I used two straps basket weaved through the middle of the frame attached to a short tow chain wrapped aroung the trunk of the tree. I should have taken pictures..... Quote
