Help
So I’m still having this problem of lag like when you full throttle it it lags for a split second then it takes off if I keep it high rpm it does not do it I have 290 mains and 27.5 pilot jets air box lid off stock motor fmf exhaust need of second notch up from bottom it was at the third in the middle I was told to move it up a notch it made tiny difference but not much have had this prob sense last yr and no one seems to know I have tried everything besides change reeds out no one rly reply’s to my post on here so that don’t help either
It’s actually mid to full Throttle but just for a split second and then takes off like you hitting nos lol
6 minutes ago, Ride2fast said:
No don’t know how but spark was black and wet
a plug chop is for a read on the main jet, its easy to do.
and if you have a stock motor with open air box and just pipes, use a stock pilot.
if your lugging it around on the bottom end of the throttle and then you go to pin it and it takes a minute to clear up, it might be getting too much gas on the low end with that pilot, just a thought you said youve tried everything right? try it and see. not like youill blow the motor up.
Ya it’s worth a shot I guess
