‘97SheeMan Posted August 31, 2017 Report Posted August 31, 2017 So I bought some k&n clamp on pod filters because I had a modified airbox that the old owner had and I decided to turn it into a dune bike so I just started my build by buying some k&n pod filters and after putting them on and revving the bike a couple of times I started to here this weird type of "EWOP" noise when the rpms go lower after I rev the shee up. You can hear it better when the volumes all the way up and you have close ish to your ear, I'm using 30mm oko Carbs, I'm ported to 375cc and have fmf pipes and k&n clamp on air filters. This is my first banshee and 2 stroke so bare with me. Sent from my iPhone using Tapatalk Quote
ginger Posted August 31, 2017 Report Posted August 31, 2017 im just curious how porting makes you have 375CC? Quote
sleeper06 Posted August 31, 2017 Report Posted August 31, 2017 What did air box set up look like, I would guess your lean now. More air you get a hollow lean pocket . Depending on how the air box set up was I would not ring its neck till you jetted it accordingly Quote
‘97SheeMan Posted August 31, 2017 Author Report Posted August 31, 2017 im just curious how porting makes you have 375CC? I'm completely new to this just saying what the owner said.Sent from my iPhone using Tapatalk Quote
‘97SheeMan Posted August 31, 2017 Author Report Posted August 31, 2017 What did air box set up look like, I would guess your lean now. More air you get a hollow lean pocket . Depending on how the air box set up was I would not ring its neck till you jetted it accordingly The airbox was more like the cut off the actual box but just had one single k&n filter.Sent from my iPhone using Tapatalk Quote
sleeper06 Posted August 31, 2017 Report Posted August 31, 2017 I couldn't hear anything either . 1 Quote
‘97SheeMan Posted August 31, 2017 Author Report Posted August 31, 2017 honestly, i don't hear anything to worry about.Some other people heard it also and said to make sure tranny oil is fullSent from my iPhone using Tapatalk Quote
97Screamer Posted August 31, 2017 Report Posted August 31, 2017 2 hours ago, ‘97SheeMan said: Some other people heard it also and said to make sure tranny oil is full Sent from my iPhone using Tapatalk From revving the bike while its sitting still? You need to stay off Facebook, sounds to me like people are messing with you! Quote
‘97SheeMan Posted August 31, 2017 Author Report Posted August 31, 2017 From revving the bike while its sitting still? You need to stay off Facebook, sounds to me like people are messing with you!All I know is my bike isn't sounding right I'll try and get a better video today if it happens again.Sent from my iPhone using Tapatalk Quote
‘97SheeMan Posted August 31, 2017 Author Report Posted August 31, 2017 where do you live?californiaSent from my iPhone using Tapatalk Quote
97Screamer Posted August 31, 2017 Report Posted August 31, 2017 2 minutes ago, ‘97SheeMan said: All I know is my bike isn't sounding right I'll try and get a better video today if it happens again. Sent from my iPhone using Tapatalk My point was when the bike is sitting trans oil is static as the cylinders/crank and trans are two different sealed systems. The oil in the trans doesn't provide lubrication to the crank or pistons, that comes from the oil in your gas. It may be the case that you need to check your transmission fluid level but I don't think you can diagnosis it through revving the bike. I have seen lots of bad advice (and lots of good to be fair) given on Facebook groups for the sake of entertaining themselves. Just be careful what you listen to. When in doubt get yourself a leak down tester and check for air leaks, then do plug chops to test jetting. Hard to blow up a bike when these are good, easy to if they're not. Quote
97Screamer Posted August 31, 2017 Report Posted August 31, 2017 Where in CA? I'm in So Cal and would be happy to help if you're around me. Quote
‘97SheeMan Posted August 31, 2017 Author Report Posted August 31, 2017 My point was when the bike is sitting trans oil is static as the cylinders/crank and trans are two different sealed systems. The oil in the trans doesn't provide lubrication to the crank or pistons, that comes from the oil in your gas. It may be the case that you need to check your transmission fluid level but I don't think you can diagnosis it through revving the bike. I have seen lots of bad advice (and lots of good to be fair) given on Facebook groups for the sake of entertaining themselves. Just be careful what you listen to. When in doubt get yourself a leak down tester and check for air leaks, then do plug chops to test jetting. Hard to blow up a bike when these are good, easy to if they're not.I cut the video to just the parts where it makes the noise, if you have earphones or just put your phone in full blast and try and listen for a "womp womp" sound between the revs. Sent from my iPhone using Tapatalk Quote
97Screamer Posted August 31, 2017 Report Posted August 31, 2017 1 minute ago, ‘97SheeMan said: I cut the video to just the parts where it makes the noise, if you have earphones or just put your phone in full blast and try and listen for a "womp womp" sound between the revs. Sent from my iPhone using Tapatalk I still don't hear anything unusual there. You're not talking about the rattle for the kicker are you? Quote
‘97SheeMan Posted August 31, 2017 Author Report Posted August 31, 2017 I still don't hear anything unusual there. You're not talking about the rattle for the kicker are you?No, sounds like rubbing I know I'm not tripping out cause I can hear it clearly if I focus on the noise, maybe it hard because I can't describe it right but for me it sounds like a womp womp Sent from my iPhone using Tapatalk Quote
