SlowMoe Posted September 1, 2017 Author Report Posted September 1, 2017 10-4 Sent from my iPhone using Tapatalk Quote
sleeper06 Posted September 1, 2017 Report Posted September 1, 2017 I always adjust timing according to feel and mark on the plugs.do some reading on plugs and play with it , good thing about timing is it's pull look reinstall and try again till you get the sweet spot. Make sure your gapping your plug @ .018-.020 Quote
SlowMoe Posted September 1, 2017 Author Report Posted September 1, 2017 150 psi compression Sent from my iPhone using Tapatalk Quote
SlowMoe Posted September 2, 2017 Author Report Posted September 2, 2017 That's after holding the throttle wide open and kicking as hard as I can about 20 times Sent from my iPhone using Tapatalk Quote
SlowMoe Posted September 3, 2017 Author Report Posted September 3, 2017 Well, is that race gas territory or what?Sent from my iPhone using Tapatalk Quote
sleeper06 Posted September 4, 2017 Report Posted September 4, 2017 I go by uccr for fuel choice and I ran some quick numbers on the calculator and your about 14:1 . Static compression varies with ex /transfer porting that's why you can't use it as a fuel indicator. When you raise your ex port your static compression will drop but your cylinders didn't shrink. So that being the case you see where I coming from. I hope blowit comments on this Quote
SlowMoe Posted September 4, 2017 Author Report Posted September 4, 2017 So for 14:1 you recommend 100% race fuel?Sent from my iPhone using Tapatalk Quote
SlowMoe Posted September 4, 2017 Author Report Posted September 4, 2017 And what is the UCCR formula? Is it cylinder displacement+ dome size/ dome size?Sent from my iPhone using Tapatalk Quote
sleeper06 Posted September 4, 2017 Report Posted September 4, 2017 Cylinder volume +trapped volume divided by trapped volume. I have two ways I do it that's why I was hoping blowit chimed in . Both ways put you in race gas territory, I gave you the highest to be safe Quote
registered user Posted September 4, 2017 Report Posted September 4, 2017 its easiest just pour oil in the plug hole then theres no guessing Quote
sleeper06 Posted September 4, 2017 Report Posted September 4, 2017 That's the easiest way I know but he's gotta do it , so tried a round about with known numbers Quote
registered user Posted September 4, 2017 Report Posted September 4, 2017 none of this story makes sense. he does a badass portjob then sends it to some guy for assembly then returns asking what gas Quote
SlowMoe Posted September 4, 2017 Author Report Posted September 4, 2017 None of what you just said makes any sense lolSent from my iPhone using Tapatalk Quote
SlowMoe Posted September 4, 2017 Author Report Posted September 4, 2017 The builder has told be more than once that 21cc domes are good for pump gas. I am doing 200cc / 21cc = 10.5:1. 10.5:1 is pump gas safe right?Sent from my iPhone using Tapatalk Quote
SlowMoe Posted September 4, 2017 Author Report Posted September 4, 2017 That was a typo I meant 221cc/21cc = 10.52:1 Sent from my iPhone using Tapatalk Quote
