CPI pipes and overrev
SlowMoe
I go by uccr for fuel choice and I ran some quick numbers on the calculator and your about 14:1 . Static compression varies with ex /transfer porting that's why you can't use it as a fuel indicator. When you raise your ex port your static compression will drop but your cylinders didn't shrink. So that being the case you see where I coming from. I hope blowit comments on this
