Scotti78 Posted August 19, 2017 Report Posted August 19, 2017 Ok guys. Need some help. Bought a 02 shee for a fixer upper. Managed to get it running pretty good overall. Except one small problem. When i hit the front brake it cuts the igniition out while riding. If its just sitting idleing and i hit the front brake it doesnt cause the problem. Only when its rolling. The front lever does have the switch for the brake light. But the brake light doesnt light up when pulled. The rear brake does work the light as its suppose to though. Just dont understand whats going on. Im assuming its grounded out somewhere causing the ignition to cut out. Any help would be greatly appreciated Quote
Ayesully810 Posted August 19, 2017 Report Posted August 19, 2017 I hate electrical. If it were me, I would seriously just eliminate everything except for what you need for the bike to run and just get a cut harness from Kory at Kompulsive concepts. That's what I did for mine, very minimal wiring and a relocated cdi. Almost no wires on the bike. But depends on weather you want all that stuff on ur bike or not. Id check your wire harness, see how everything looks Quote
Scotti78 Posted August 19, 2017 Author Report Posted August 19, 2017 Yeah thats probably what im gonna end up doing. All i want is a kill switch no keyswitch and 2 headlights. Highbeam only and no brake light . Im just wondering if im correct about the switch wiring shorted out to the fram somewhere and jacking up the voltage to my ignition Quote
IceracerX Posted August 19, 2017 Report Posted August 19, 2017 did you try disonnecting the switch? Quote
Scotti78 Posted August 19, 2017 Author Report Posted August 19, 2017 Thats what im gonna try today and see what it does. Ran out of time last night Quote
hoppedupandcutdown Posted August 19, 2017 Report Posted August 19, 2017 I'm gonna say you just have to have a wire somewhere grounding out when it nosedives hitting the front brake. Check the orange wire on the coil for bare spots too. Quote
sleeper06 Posted August 19, 2017 Report Posted August 19, 2017 Probably a chafed wire somewhere, you could look at the harness real good, usually not that hard to find most bikes that were touched in the past never had the harness routed correctly and they rub on something Quote
Ayesully810 Posted August 19, 2017 Report Posted August 19, 2017 5 hours ago, Scotti78 said: Yeah thats probably what im gonna end up doing. All i want is a kill switch no keyswitch and 2 headlights. Highbeam only and no brake light . Im just wondering if im correct about the switch wiring shorted out to the fram somewhere and jacking up the voltage to my ignition good idea. you can get a cut harness from Kory for like 40 bucks or so then get a cdi relocation bracket. Should be able to eliminate that rats nest for 60 bucks or so! lol Quote
Scotti78 Posted August 20, 2017 Author Report Posted August 20, 2017 20 hours ago, Ayesully810 said: good idea. you can get a cut harness from Kory for like 40 bucks or so then get a cdi relocation bracket. Should be able to eliminate that rats nest for 60 bucks or so! lol Sounds good man. I have found another problem while going threw this bike and freshening it up. The right side cylinder wont fire everytime like it should. To match the left side at idle. But as soon as i give it just a tiny bit of fuel it clears up and does great. Ive been threw the carbs a 100 times cleaning them and syncing them. You name it. So i decided to pull the reeds out and check them. Both sides need replaced they are very very think. But one of them on the right side has a pretty good chunk missing from it and will not close all the way. Could that be whats causing that cylinder to not idle properly? Quote
Scotti78 Posted August 20, 2017 Author Report Posted August 20, 2017 Btw. Unhooked both brake switches and removed the tail light. And the ignition problem disappeared with it. So it must have been something jacked up in the brake wiring Quote
