EaCastillo00 Posted July 28, 2017 Report Posted July 28, 2017 Guys somenone told me that once i installed the Vforce 4 reeds my banshee would swallow gas like its water, they even said my stock tank would last like 30 kms tops, is it true? Quote
Ayesully810 Posted July 28, 2017 Report Posted July 28, 2017 That is not true. Bigger carbs is what is going to have the most impact on your mpg. I ran 35 pwks on my 421 setup and it drank gas I got maybe an hour on a tank if I was lucky. I just switched to stock carbs (even though its not the ideal carb for peak HP) and the mpg gas improved drastically. But the answer to your question is no. Quote
jeremyshee01 Posted July 28, 2017 Report Posted July 28, 2017 How was the throttle response between the 35's and stock? Sorry to jump the thread, I'm in the process of doing the opposite (stock to 35mm on my 421)Sent from my SCH-I535 using Tapatalk Quote
ginger Posted July 28, 2017 Report Posted July 28, 2017 bottom end will fall off some, top end will gain some. Quote
Ayesully810 Posted July 28, 2017 Report Posted July 28, 2017 15 hours ago, jeremyshee01 said: How was the throttle response between the 35's and stock? Sorry to jump the thread, I'm in the process of doing the opposite (stock to 35mm on my 421) Sent from my SCH-I535 using Tapatalk I honestly prefer the stockers over my 35s for my trail setup. The throttle response is instant and the bike is literally always in the power it seems like. On pump with stockers it still makes 73 horse and 44 torque. I switched from race fuel to pump as well as carbs so the power doesnt hit as hard obviously but my mpg rocks and it will still do 80mph quickly if i need to. Quote
