Bikelife305 Posted July 26, 2017 Report Posted July 26, 2017 Should the bike shut off when pulling one spark plug wire or would it just shut off the side that the wire was pulled off? Quote
Ayesully810 Posted July 27, 2017 Report Posted July 27, 2017 Both plugs fire at the same time. Only the side you take the cap off of the plug should shut off. Why do you ask? Are you trying to diagnose a spark issue? Quote
hicksons Posted July 27, 2017 Report Posted July 27, 2017 On cylinder should fire still sounds horrible but will still runSent from my iPhone using Tapatalk Quote
Bikelife305 Posted July 27, 2017 Author Report Posted July 27, 2017 33 minutes ago, Ayesully810 said: Both plugs fire at the same time. Only the side you take the cap off of the plug should shut off. Why do you ask? Are you trying to diagnose a spark issue? I'm having that issue on one side not starting till I hit the throttle then it would startup then on idle it back cold 1 Quote
Keno Posted July 27, 2017 Report Posted July 27, 2017 Do you have a carb sync tool? Sounds like your carbs need synced Quote
Bikelife305 Posted July 27, 2017 Author Report Posted July 27, 2017 9 minutes ago, Keno said: Do you have a carb sync tool? Sounds like your carbs need synced Carb are sync Quote
Ayesully810 Posted July 27, 2017 Report Posted July 27, 2017 trim some wire off of your spark plug wires about 1/4 inch then plug boots back on, try again. also make sure your pick up coil gap is set correctly. I set mine at .018 Quote
Bikelife305 Posted July 27, 2017 Author Report Posted July 27, 2017 (edited) 10 minutes ago, Ayesully810 said: trim some wire off of your spark plug wires about 1/4 inch then plug boots back on, try again. also make sure your pick up coil gap is set correctly. I set mine at .018 I try two different coils.. but haven't check the pickup gap Edited July 27, 2017 by Bikelife305 Quote
ginger Posted July 27, 2017 Report Posted July 27, 2017 it sounds like a carb sync deal to me as well. Quote
blowit Posted July 27, 2017 Report Posted July 27, 2017 Agree with above. Carb sync sounds most likely. You can simply swap your plug wires side to side. If problems follow the wire, you have a wire problem. If not, you have other issues. Remove the airbox or filters so you can see the slides. Sometimes you can peek through the box. You will likely see one slide much higher than the other. Reeds are certainly possible but the carb check might be an easier check first. In many cases over the years, we see people messing with something on the bike and get the adjuster on top of the carbs not "seating" right. Make sure the cable ends are in their home! We also see where the cable will fray and cause issues. 1 Quote
sleeper06 Posted July 27, 2017 Report Posted July 27, 2017 Like I said in his other post most people mistake cable play/pull adjustment for sync , there two different adjustments Quote
