Can I run 68mm pistons in the stock cylinders or do I need to get aftermarket cylinders?
Stock sleeves can run up to 66.50mm. But the structural integrity of the sleeve is weak at the bottom and you can have cooling issues. Most don't go larger than 66mm. 68mm is the size of the standard cub bore.
