Included in the sale, blue tank and shroud cover as well as OEM plastic grille insert and mounting bolts. I will post in another pic the hole drilled for the key to be mounted. These are in great shape.  $150 plus ride and PP fees. There is a faint light spot on these.... top rear of the right side in picture  *** Note Red plastics are for sale but not in this post (front and rear red drag cut)
Also for sale a full intake package all as seen in pic. 34PJ Alcohol carbs with power-jets, K&N Pods, Throttle Cable, Reed Spacers, Boysen Reeds and Stock Reed cages, Intakes with crossover tube along with new gaskets. All have just been cleaned and are ready for install.  I will send carb specs to interested parties set up for SB Cub . 350 plus pp and ride.
Stock OEM seat with Cascade blue white and gray cover in great condition. Hole from a branch poked through on top right corner (2nd pic) other than that great shape. 120 plus PP and shipping.
On 7/7/2017 at 0:25 PM, Chukkinsod said:
For some reason it states you cant receive messages.... Red ones I have are drag cut and front you see above....only lower fronts. I can text u pics
yeah loco's workin on it...race cut's fine... pic's & $
