30years Posted June 13, 2017 Report Share Posted June 13, 2017 (edited) Stock frame banshee.10 mil cub, setup on alkyFull drag port by K & THave the needles to run race or pump gas. Also have floats to run pump feed.+ 12 swingarm14 paddle staggered extreme haulers on drag cut blue labels, 76" ro (almost brand new) WCR extreme duneabale 2 thru 5 neutral downcentrifugal lock up full polished Packard Lectrons 40mm bored to 41.5mmChariot O ringed headV force 3'sDual pingleK&N pods with outerwearsChain tensionerHigh tensile strength non o-ring chainFAST racing clutch plates and fibersAftermarket tie rodsMarvin Shaw frontscurrently setup rigid rear with full wheelie bar which is easily removablesmall bore Shearers both out of left sideJJ&A play axledouglas blue label frontsdynatek iginitionI don't know why I should have to even explain any of this. Just look at the pictures. It's not a bunch of thrown together crap. lots of other extras to possibly go with, might be negotiable on other parts to go with a sale frame is titledburned a plug strap in winter of 2015 on Anchor Bay, had cylinders sent out to millennium technologies to be honed and nikasiled, new pistons, rings, and TZ and Max Load bearings along with freshen up Have had probably 8 track passes since new. I still don't have it set to it's potential.Didn't run it at all last summer except for running a little alky through it then purging, only to be stored in garage!have videos Edited June 13, 2017 by 30years Quote Link to comment Share on other sites More sharing options...
Soli Posted June 14, 2017 Report Share Posted June 14, 2017 Stock frame banshee.10 mil cub, setup on alkyFull drag port by K & THave the needles to run race or pump gas. Also have floats to run pump feed.+ 12 swingarm14 paddle staggered extreme haulers on drag cut blue labels, 76" ro (almost brand new) WCR extreme duneabale 2 thru 5 neutral downcentrifugal lock up full polished Packard Lectrons 40mm bored to 41.5mmChariot O ringed headV force 3'sDual pingleK&N pods with outerwearsChain tensionerHigh tensile strength non o-ring chainFAST racing clutch plates and fibersAftermarket tie rodsMarvin Shaw frontscurrently setup rigid rear with full wheelie bar which is easily removablesmall bore Shearers both out of left sideJJ&A play axledouglas blue label frontsdynatek iginitionI don't know why I should have to even explain any of this. Just look at the pictures. It's not a bunch of thrown together crap. lots of other extras to possibly go with, might be negotiable on other parts to go with a sale frame is titledburned a plug strap in winter of 2015 on Anchor Bay, had cylinders sent out to millennium technologies to be honed and nikasiled, new pistons, rings, and TZ and Max Load bearings along with freshen up Have had probably 8 track passes since new. I still don't have it set to it's potential.Didn't run it at all last summer except for running a little alky through it then purging, only to be stored in garage!have videosPics?Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
30years Posted June 14, 2017 Author Report Share Posted June 14, 2017 I'm trying to figure out how to delete the whole post so I can do it again properly. 1 Quote Link to comment Share on other sites More sharing options...
30years Posted June 14, 2017 Author Report Share Posted June 14, 2017 please delete this post, thank you Quote Link to comment Share on other sites More sharing options...
