Stock frame banshee.
10 mil cub, setup on alky
Full drag port by K & T
Have the needles to run race or pump gas. Also have floats to run pump feed.
+ 12 swingarm
14 paddle staggered extreme haulers on drag cut blue labels, 76" ro (almost brand new)
WCR extreme duneabale 2 thru 5 neutral down
centrifugal lock up
full polished Packard Lectrons 40mm bored to 41.5mm
Chariot O ringed head
V force 3's
Dual pingle
K&N pods with outerwears
Chain tensioner
High tensile strength non o-ring chain
FAST racing clutch plates and fibers
Aftermarket tie rods
Marvin Shaw fronts
currently setup rigid rear with full wheelie bar which is easily removable
small bore Shearers both out of left side
JJ&A play axle
douglas blue label fronts
dynatek iginition
I don't know why I should have to even explain any of this. Just look at the pictures. It's not a bunch of thrown together crap.
lots of other extras to possibly go with, might be negotiable on other parts to go with a sale
frame is titled
burned a plug strap in winter of 2015 on Anchor Bay, had cylinders sent out to millennium technologies to be honed and nikasiled, new pistons, rings, and TZ and Max Load bearings along with freshen up
Have had probably 8 track passes since new. I still don't have it set to it's potential.
Didn't run it at all last summer except for running a little alky through it then purging, only to be stored in garage!
have videos
Edited by 30years
+ 12 swingarm
centrifugal lock up
V force 3's
Dual pingle
Chain tensioner
Marvin Shaw fronts
JJ&A play axle
dynatek iginition
frame is titled
have videos
Pics?
