pattheriault Posted March 1, 2017 Report Posted March 1, 2017 What can cause this piston to be as bad and the other one to be in perfect shape? id say around 300km on the 4mil rebuilt Could a bad spark cause this? on my last ride the terminal nut came loose on the plug and it ran on 1 cyl for a short period of time. Quote
sheerider11 Posted March 1, 2017 Report Posted March 1, 2017 That's a lean condition. Need to figure out why. Air leak or carb issue Quote
pattheriault Posted March 1, 2017 Author Report Posted March 1, 2017 yeah kind of what I figured... will need to find out why.. Would you guys go ahead and split the case to inspect for metal shaving in a situation like this? crank seems tight and in good shape. Quote
RagunCajun Posted March 1, 2017 Report Posted March 1, 2017 Did you do a leak down test before disassembly? Quote
pattheriault Posted March 1, 2017 Author Report Posted March 1, 2017 No i did not.. I suspect an air leak as my carb were cleaned when i did my rebuild but ill inspect them tomorrow Quote
J-Madd Posted March 1, 2017 Report Posted March 1, 2017 Should've done a leak down test before tear down, but we've all probably been hasty to tear one down and forgot at one point. If the bore is ok you can run a hone through it and put a new piston in there. Test for air leak before starting and also report your mods and jetting specs. 1 Quote
pattheriault Posted March 1, 2017 Author Report Posted March 1, 2017 4mil, fast dune port, shearer, pod filter,.20 over,24cc dome,+4 degree, vforce 4, 360 main 30 pilot Quote
pattheriault Posted March 1, 2017 Author Report Posted March 1, 2017 Ill try to clean the jug tomorrow but they have a bit of material from the piston on them. I think ill have to bore to 65mm Quote
J-Madd Posted March 2, 2017 Report Posted March 2, 2017 Ill try to clean the jug tomorrow but they have a bit of material from the piston on them. I think ill have to bore to 65mmMay try some muratic acid on the bore. It will take the aluminum off. But I bet you're bore is scarred if that happened. Quote
pattheriault Posted March 2, 2017 Author Report Posted March 2, 2017 is there a trick to take the screws out to take out the little plate behind the clutch (Bearing stopper plate)?? they are in there pretty tight and im afraid to strip them in.. Quote
pattheriault Posted March 2, 2017 Author Report Posted March 2, 2017 Thanks! worked like a charm Quote
