Got the banshee about a year and a half ago with a seized engine and had it fully rebuild and every seens she was rebuilt the stator will burn out after 20/30 mins this has happened 3 times now and I have a a new banshee wiring loom put in her
Sent from my iPhone using Tapatalk Pro
Jum aftermarket
Also would like to see inside to flywheel, but anyways, i would try with a oem, if you have somebody that can to give you one and you can test, some many people don't trust in aftermarket flywheel's and stator but maybe is just lucky
Check the gasket of stator cover maybe get in dust or dirt or some shit into stator
Sent from my HUAWEI P6-U06 using Tapatalk
Jum aftermarket
I'll have move pic up at the weekend parts for banshee are getting very hard to find here in Ireland but I'll try to find a oem flyweel.
I will jump in and offer advice here.  I will need to know if you are losing the lighting output or spark?  Also, what is your skill level and what sort of test meters do you have available?
Mull Engineering
Mull Engineering
She isn't getting spark skill level wod b average and I have a multimeter at hand just
The very first thing to do is test the resistance in the ignition coil.  This will be the Red and Green wires.  If you read OL or very high resistance, probe inside the stator directly where the magnet wire is soldered to the leads.
Remember also, always put your meter leads together and see what the internal resistance is first and add that to your test figure.
Once we know if the coil is open or not, we can figure more things out.
