RagunCajun Posted November 14, 2016 Report Posted November 14, 2016 I change the oil and filter after each trip How many hours on the engine is each trip? Is it mostly WOT riding? Quote
rubberneck Posted November 14, 2016 Report Posted November 14, 2016 How many hours on the engine is each trip? Is it mostly WOT riding? It depends, it usually works out to about every 10 hours. I only ride in the sand, so yeah im on it pretty hard most of the time. Quote
rubberneck Posted November 14, 2016 Report Posted November 14, 2016 also.. if you looking at cost... if you do oil changes by the 5-10 hour ride time mark and if you use expensive premium oil.. youl spend just as much in oil changes on the 4poke as you would re doing a top end on a 2 poke.... But you arent buying 2 stroke oil and premium oil isnt cheap there either. i buy redline 4 stroke motor oil on amazon no its not cheap but it doesnt use a ton either. I think a lot of guys run 15-40 diesel oil, so there is that option too Quote
Chukkinsod Posted November 14, 2016 Report Posted November 14, 2016 Keep an eye on the timing chain adjusters too...all fun and games till you skip a tooth on the chain and your valves smack the piston boogering up the valves, seats, head and piston. Rebuilds are WAY more expensive and many times require a machine shop for head /valve recut Quote
sheerider11 Posted November 14, 2016 Report Posted November 14, 2016 But you arent buying 2 stroke oil and premium oil isnt cheap there either. i buy redline 4 stroke motor oil on amazon no its not cheap but it doesnt use a ton either. I think a lot of guys run 15-40 diesel oil, so there is that option tooThis. I run Rotella. In the banshee, 450, and street bike. Every ride or 2 I'll change it. Quote
