Durf4693 Posted October 6, 2016 Report Posted October 6, 2016 I'm working on a banshee for my buddy. Has an Athena motor with coolhead, 34 PJ carbs, aftermarket CDI, can't tell if timing is advanced,( didn't want to take off flywheel) Should I be running B8ES? Or 9's? Also where do you think I should be at for compression to run 93 octane, oil mix ratio suggestions ? 1 Quote
bigweav81 Posted October 6, 2016 Report Posted October 6, 2016 Sounds like he needs some help. Sent from my SM-S820L using Tapatalk Quote
J-Madd Posted October 6, 2016 Report Posted October 6, 2016 Run B8's on gas. If you don't see an adjustable timing plate or notice where the stock plate has been modded (bolt holes will be oblong instead of round) then timing is stock. If stock plate happens to be modded about +5 is as far as it will go. 32:1 on the ratio. I can't answer those other questions without more info. Leak down test it, check compression and report back. Quote
Ayesully810 Posted October 7, 2016 Report Posted October 7, 2016 Nicely replied.... im having a shit day lol eat a snickers jess Quote
Durf4693 Posted October 8, 2016 Author Report Posted October 8, 2016 Alright thanks gentlemen, I've never fucked with an Athena motor ,just trying to put him in the right direction without destroying the bike. I'll get some compression and check back. He bought the bike knowing nothing about them so he asked me to take a wrench to it. I'm just replacing shit, chain rollers,fluids, cleaning the pods and carbs, epoxying chain whack, fixing tether switch, wrapping the exhaust by pods, new nerf bars blah blah 1 Quote
Durf4693 Posted November 10, 2016 Author Report Posted November 10, 2016 Around 135-145 compression, 93 octane should be ok ? Which way on the nut of the choke lever increases the idle ? PJ's. Quote
trickedcarbine Posted November 10, 2016 Report Posted November 10, 2016 Screw them all the way in clock wise till they stop. Use a paint pen to mark the knobs. Back them out 6 1/2 - 7 1/2 turns. Quote
Durf4693 Posted November 11, 2016 Author Report Posted November 11, 2016 Does that nut lock them ? Quote
trickedcarbine Posted November 11, 2016 Report Posted November 11, 2016 No. That's why I say mark them so you'll know if they've moved. Quote
