hercalmighty Posted July 20, 2016 Report Posted July 20, 2016 What pilots are you running? What needle and clip position? What is your compression? Are you sure the carbs are 38mm non Airstrikers? Regular PWKs go 35mm and 39mm. Airstrikers are 35mm and 38mm. Sent from my VS990 using Tapatalk Quote
james97gt Posted July 21, 2016 Author Report Posted July 21, 2016 Stock cdi stock stater lightened fly wheel. I checked the compression only has 150 I assume it has stock cheetah domes does this sound right ? Quote
