awblackmamba Posted July 12, 2016 Report Posted July 12, 2016 The lock nut that goes on the adjustment shaft skeptical on how its gonna lock on a thread or two. Its an fast hd clutch with almost brand new clutch cable and cascade pusher. tell me what you think? Quote
sheerider11 Posted July 12, 2016 Report Posted July 12, 2016 Did you bottom out the adjuster or do it as per manual? It looks like you just ran it in all the way Quote
awblackmamba Posted July 12, 2016 Author Report Posted July 12, 2016 I had to to get the cable right like the plates are just a bit thicker than the stockers. Quote
bigweav81 Posted July 13, 2016 Report Posted July 13, 2016 Did your pancake bearing not come with a longer adjuster bolt? Sent from my SM-S820L using Tapatalk 1 Quote
Bennett131 Posted July 13, 2016 Report Posted July 13, 2016 Did your pancake bearing not come with a longer adjuster bolt? Sent from my SM-S820L using Tapatalk It's the longer bolt only used if running an 8 plate clutch? Quote
bigweav81 Posted July 13, 2016 Report Posted July 13, 2016 I believe it is for 8 plates, but it couldn't hurt to throw it in, and see what kind of adjustment you get? Sent from my SM-S820L using Tapatalk Quote
hoppedupandcutdown Posted July 13, 2016 Report Posted July 13, 2016 I had to to get the cable right like the plates are just a bit thicker than the stockers. You need to adjust the pancake with the cable completely loose. Quote
awblackmamba Posted July 14, 2016 Author Report Posted July 14, 2016 when i bought the cascade adjuster it only had on bolt with it can you buy the longer bolt? I adjusted it with cable completely loose and the lock nut doesn't have any threads to safely lock it on. Quote
awblackmamba Posted July 14, 2016 Author Report Posted July 14, 2016 with the worn clutch it had just enough threads for it to lock down safely. Quote
sheerider11 Posted July 14, 2016 Report Posted July 14, 2016 when i bought the cascade adjuster it only had on bolt with it can you buy the longer bolt? I adjusted it with cable completely loose and the lock nut doesn't have any threads to safely lock it on. did you pull the actuator to line the arrows up? Quote
