jiiic Posted May 9, 2016 Report Posted May 9, 2016 i am looking for the right side rear fender mount which is the 90 degree one not the straight one i know alot of guys running cut rear fenders clean up the frame and eliminate them... the previous owner cut both of the rear fender mounts off fortunatly i was able to get the left one but not the right.. i am willing to pay shipping and a little more any help would be appreciated thanks Quote
Oldskool83 Posted May 9, 2016 Report Posted May 9, 2016 partzilla.com buy new ones but my banshee never had fender mounts in the rear lol Quote
jiiic Posted May 9, 2016 Author Report Posted May 9, 2016 these are a weld on mount.....they are pretty much the only thing to support the lower part of full fenders once the heel guard is eliminated ...I looked on partzilla but I may not have been looking in the right place. Quote
sheerider11 Posted May 9, 2016 Report Posted May 9, 2016 these are a weld on mount.....they are pretty much the only thing to support the lower part of full fenders once the heel guard is eliminated ...I looked on partzilla but I may not have been looking in the right place.if you have a half decent hand, make your own. Quote
jiiic Posted May 10, 2016 Author Report Posted May 10, 2016 I have one bent not sure if its the same angle on the bend im just worried about the end where its flattened out i want it to look as factory as possible i was just hoping someone might have on laying around. Quote
sheerider11 Posted May 10, 2016 Report Posted May 10, 2016 I have one bent not sure if its the same angle on the bend im just worried about the end where its flattened out i want it to look as factory as possible i was just hoping someone might have on laying around.eh. Most cut them and they go right in the trash. You need to find someone that it ready to do it and they know you want it. Quote
Oldskool83 Posted May 10, 2016 Report Posted May 10, 2016 (edited) they make a rear fender mount out of aluminum. I run one and it bolts on. http://www.ebay.com/itm/Modquad-Rear-Fender-Bracket-Aluminum-For-Yamaha-Banshee-1987-2006-/191201088566?hash=item2c84791436:g:xTYAAOSwnipWT8ro&vxp=mtr The lower mount just weld back on 1/4 tube and drill a hole in it. The factory mounts for the lower fenders are pretty bad. I gusseted my factory frame all up in many places. You can't buy those mounts unless you buy another frame for 1 mount. Edited May 10, 2016 by Oldskool83 1 Quote
jiiic Posted May 10, 2016 Author Report Posted May 10, 2016 i will have to order a set of those thanks and as for the lower i will just continue my fabrication of one i guess i was just looking for the easy way out. Quote
bhatch21 Posted May 12, 2016 Report Posted May 12, 2016 they make a rear fender mount out of aluminum. I run one and it bolts on. http://www.ebay.com/itm/Modquad-Rear-Fender-Bracket-Aluminum-For-Yamaha-Banshee-1987-2006-/191201088566?hash=item2c84791436:g:xTYAAOSwnipWT8ro&vxp=mtr That link is for an upper rear fender support. It bolts into the existing upper rear fender mount/grab bar and extends out to help hold up the flared upper portion of the rear fenders. I have two sets and they are great ammo against the common banshee rear fender sag. Quote
