Whatever you buy, make sure the dome's are correct for your motor. If you aren't physically measuring to be sure, you are doing it wrong. Also, if the big O-rings around the cylinder bore aren't Viton, they are garbage.
I have this one ^^. No complaints at all. If you go with the Pro Design you have to switch out your head studs and use an o ring on each stud where the Driveline head you don't have to do either.
Do you have to use cool head specific orings for the studs or can you use any run of the mill o ring?
Regular o rings, but certain hardware stores won't have them.
I haven't looked in any hardware stores, When I bought my head I ordered an extra kit just to have. The Pro Design kit comes with all the little stud o rings as well, but those are not needed for the other cool heads.
I recently bought a stock head that's a stealth style from driveline. Its cool shit! I'm not into all the shiny shit.
It's about as sleeper as it gets in my opinion.........well besides Carl.
sent from yo mammy house.
Pics?
