SHIFT PROBLEMS
KwikShee
I have a 98 banshee and I split the cases for new seals while my cylinders are being bored and ported. I have everything in up to the transmission. Shift cam, shift star, rods & forks, adjustment bolt, shift shaft and shifter and transmission itself. It will shift 1st neutral and second but hangs up on the point of the shift star between second and third. I've taken it apart 3 times and put it together following my yamaha book and lower end walk through pics on here. I would assume u should be able to shift through all six vut maybe I'm wrong. I slid the upper case on but no clutch or basket, idler gear, etc. Hand shifted with it on the table. Any help greatly appreciated
  • 1 month later...
