braptor52 Posted March 16, 2016 Author Report Posted March 16, 2016 Chariot makes there own I believe Sent from my iPhone using Tapatalk Quote
Deadbeat Posted March 16, 2016 Report Posted March 16, 2016 very good option here http://bansheehq.com/forums/index.php?/topic/177830-driveline-performance-stock-head-mod/page-1 Quote
braptor52 Posted March 17, 2016 Author Report Posted March 17, 2016 That is pretty cool it doesn't appear they have them for sale on there website though? Sent from my iPhone using Tapatalk Quote
Deadbeat Posted March 17, 2016 Report Posted March 17, 2016 just message Bill direct, he can hook you up with whatever you need for your motor http://bansheehq.com/forums/index.php?/user/34717-banshee-hp/ Quote
braptor52 Posted March 17, 2016 Author Report Posted March 17, 2016 (edited) So pulled the head off. Actually came off pretty easily. I was hoping this would be the case since I did start the motor and ran it through couple heat cycles previously. Anyways here's a pic of the studs. Right side would not thread as far as the left Also found a small thread shaving that looks to have chipped off one of the domes where the plugs thread in when I removed the head. Musta fallen in last night when I installed the plugs luckily I didn't start motor and I pulled the head off... Was a little concerned when I got these new domes also because one of them fit more snug in the head compared to other one. Sent from my iPhone using Tapatalk Edited March 17, 2016 by braptor52 Quote
braptor52 Posted March 17, 2016 Author Report Posted March 17, 2016 just message Bill direct, he can hook you up with whatever you need for your motor http://bansheehq.com/forums/index.php?/user/34717-banshee-hp/ Thank you that's a route I may go Sent from my iPhone using Tapatalk Quote
braptor52 Posted March 17, 2016 Author Report Posted March 17, 2016 Took a pick tool and was able to peel up more material around plug. I know I snugged these up but I know I didn't tighten them hard enough to start stripping the hole out. Glad I removed this head... Sent from my iPhone using Tapatalk Quote
braptor52 Posted March 17, 2016 Author Report Posted March 17, 2016 (edited) And if I didn't have enough problems I just noticed all this black sand gritty stuff in the cooling system. It's made its way everywhere. Never noticed it when I drained it initially. I know this bike has been in the sand but I don't recall ever seeing this before. I flushed the radiator out and washed the new cylinders before I went back together. Dono where it's from maybe from the cylinders left over casting material? Sent from my iPhone using Tapatalk Edited March 17, 2016 by braptor52 Quote
sheerider11 Posted March 17, 2016 Report Posted March 17, 2016 So pulled the head off. Actually came off pretty easily. I was hoping this would be the case since I did start the motor and ran it through couple heat cycles previously. Anyways here's a pic of the studs. Right side would not thread as far as the left Also found a small thread shaving that looks to have chipped off one of the domes where the plugs thread in when I removed the head. Musta fallen in last night when I installed the plugs luckily I didn't start motor and I pulled the head off... Was a little concerned when I got these new domes also because one of them fit more snug in the head compared to other one. Sent from my iPhone using Tapatalk The first picture. I don't know if the studs are way off, or if the water jackets are cast bad. But that is way off. Quote
sleeper06 Posted March 17, 2016 Report Posted March 17, 2016 .050-.060 on swish is a huge diffrence so which is it . How are you checking it? If your only testing one side readings will be higher due to piston rock on the pin , you need to have solder on both sides to get correct squish . You should have a smaller number towards the cylinder wall and get a lil bigger towards plug hole if domes are cut correctly Quote
sheerider11 Posted March 17, 2016 Report Posted March 17, 2016 When you guys talk about the water jacket having bad casting, are you talking about how the stud isn't centers between the two? That and the difference in how far they are from the out side of the cylinder. I can't draw on pics like that but just a little down and in towards the center, they appear way different Quote
sheerider11 Posted March 17, 2016 Report Posted March 17, 2016 You do know the off center is OEM right? Nope. Haven't seen an oem head in person in like 2 years Quote
sheerider11 Posted March 17, 2016 Report Posted March 17, 2016 Here is an above picture of OEM cylinders Hmmm. Well nothing I can see that stands out then. Quote
braptor52 Posted March 17, 2016 Author Report Posted March 17, 2016 (edited) am I the only one wondering what type of cell he's using to take pictures? them fuckers are crystal clear! lol.... Your on the right track with these guys guidance!!! As mentioned either the water jackets are off center or the studs are.... USUALLY if the studs where off center the head wouldnt slide on and off easy... odds are the cylinders werent poured perfectly and are off center? When you received the cylinders did you only clean the ports or did you also previously clean them out a-z... (including water jackets) Usually ill throw some compressed air through the whole cyl before instal I was test fitting the trinity head over the cylinders last night and they fit smoothley but the heads or the cylinders are shaped differently. I'll get a few pictures of what I'm talking about. Oh and I'm using a iPhone 6 to take all my pictures haha it works good especially in my sorry garage lighting. I didn't even think about casting sand when I cleaned the cylinders before I installed them. I was worried about metal shavings so I just washed them with hot soapy water in the sink and let air dry. I think if I were to boil some water then let it cool a tad bit and then drop the cylinders in an let them soak it may have loosened up the sand. I have a hot jet parts washer at work I could try too. Sent from my iPhone using Tapatalk Edited March 17, 2016 by braptor52 Quote
braptor52 Posted March 17, 2016 Author Report Posted March 17, 2016 .050-.060 on swish is a huge diffrence so which is it . How are you checking it? If your only testing one side readings will be higher due to piston rock on the pin , you need to have solder on both sides to get correct squish . You should have a smaller number towards the cylinder wall and get a lil bigger towards plug hole if domes are cut correctly My squish was actually .055 on left cylinder and .058 on right cylinder. I measured each cylinder on both sides of piston above wrist pin with solder and through the spark plug hole Sent from my iPhone using Tapatalk Quote
