I recently tore my engine apart to replace my crank seals. I was wondering if I have to hone the cylinder because I removed it? And also, can I use the same rings or should I buy new ones? I'm new to this and just bought my banshee last year.
  • Like 1
Imo you should have the clearanced checked by a good machine or honing shop. Once he checks cylinder for trueness of bore and piston to cylinder clearance you can make your choice . If you don't have access to anything start with a fresh bore n new Pistons . It pays to get your crank trued n welded also
Did you check what compression was before the tear down? Can you see a good cross hatch in the cylinder? Also, check the piston skirt area vs the top of the piston. There will be some taper, but figure out what pistons are in there and what the alowable collapse is. If all is well, definitely toss new rings in there at a minimum.
