My banshee was taken apart to be resprayed, it's coming together nicely right now and it's near completion. The only trouble I'm having is the cable routes, the wiring harness runs from the back up the inside of the frame and under the fuel tank. The only problem is that there are certain plugs like the kill switch connector that barely reaches the wiring harness. When I turn the steering the kill switch stretches, so obviously the routing Isn't right. I was wondering if anyone could tell me the routing for the harness and the break cables ect. Did you run the breaks down the center of the tank, does it cross in front of the steering rack or underneath it? Any help would be great.
  • 2 months later...
Pick up a clymer or yamaha manual. There are diagrams for cables, wiring, hoses etc. Definitely need one if you plan on doing things right. They are worth their weight in gold.
