Ok but the bolt was stuck ...would not move @ all bread fluid will loosen the bolt I was using wd40?
Sent from my SAMSUNG-SM-G920A using Tapatalk
brake fluid will get through better then wd or pb. That's why I say put it on now so it has time to soak in and hopefully help it break loose
I work on a lot of old stuff. I've found this works well. It has worked for me when nothing else did. Since it works by freezing I'm careful using it on cast parts.
http://www.amazon.com/CRC-05002-Freeze-Off-Super-Penetrant/dp/B000TFTH00
Edited by Time Machine
Buy a new caliper
  • 1 month later...
