I currently have 21x12x8 7 paddle haulers with a 69 inch rollout . They are mounted on dwt wheels (8x7) .
Do they make 8x6 inch wheels ? ive been looking but i have only found them in a 4/110 .
Thanks guys appreciate the advice
Put air in em and set them in the sun. Or buy bigger tires. :)
summer just passed so thinking about buying a new set . Is their a big diffrence from the standard buff and b2b ?
  • 1 year later...
thats a odd RO.   I'm pretty sure they dont make a 8x6 rim.   id sell them and go with a different set up if you are looking for a bigger RO. Typically a 22-11-8 tire will be around 72 ish RO.  That will change a little with a 8x7 or 8x8 wheel. Some of the newer superlights are around 73-74 RO.   Just my opinon.  Good luck.
as far as weight a little, but rotating mass is everything in the drag world.  not really noticable in a dunner.  But all my dunners run triple buff superlights and I haven't had any problems puncturing them.  The new carcusses are a little thicker then the old ultra lights from years ago.  Skat trak might not the weight difference between the two.
