Gemeiner Posted November 7, 2015 Author Report Posted November 7, 2015 K so I went to glamis last weekend and it ran perfect with the 30 pilots and 310 mains. So when I got home I dropped to 27.5 pilot and 270 mains. Needle is 2nd from the bottom so it's rich. Powerband and top end is great but idle to powerband sucks. Turning the air screws in helps the problem but since I'm 1 turn out and still have the problem and the needle is set so rich to begin with, don't you think I should bump it up to 30? I think I was close on my pilot before with the 30s, never had this problem. But Ill need to purl the the clip higher on the needles for sure Quote
Gemeiner Posted November 7, 2015 Author Report Posted November 7, 2015 Idk if another half turn in will do it but I'll try it. Just seems weird Quote
Gemeiner Posted November 7, 2015 Author Report Posted November 7, 2015 At idle with the 27.5s when I snap the throttle at all, the rpms stay high. No air leaks. I know it's bored, idk how much it's bored over or how much it would affect it. Quote
camp0429 Posted November 7, 2015 Report Posted November 7, 2015 If you rpm's "stays high", that's more than likely a lean rev (or throttle cable/slide sticking, had that happen before) If its definatly a lean rev, could be caused by air leak or too small pilot. Also you said it sucks until you hit powerband, don't rule out your needle yet. Your pilot and needle gotta be happy with each other at that point Quote
Gemeiner Posted November 7, 2015 Author Report Posted November 7, 2015 Only reason I don't think it's the needle is because it was only one above the bottom position. I always check the slide and cable cuz I've had that too lol. I wanna say I need the 30 pilots but they worked fine 4000 feet lower than where I am just last weekend so I SHOULD be good with the 27.5s.. just kinda weird Quote
Gemeiner Posted November 7, 2015 Author Report Posted November 7, 2015 To reword that, the 30s work at sea lvl and I'm at 4000 so I should need a smaller one. But I've used the 30s up here and had no problems. But I know it could rob power if it's too big Quote
