I currently have 9.5vac at idle and can't get over 11vac at any rpm above. I easily produce 20 plus volts without the regulator so I assume the stator is fine. Also have tried a couple different regulators all with same results. Any suggestions why I can't get 12vac or should I ? Does the regulator require a load from the lights to produce proper voltage ?
Just wanting to insure my ac side is correct before I troubleshoot too much with the dc rectified side of the rectifier I'm running
Very south eastern tip, town called Middlesboro. I tested un regulated and I don't know the exact voltage output but I do remember reaching over 20v ac in a rev and it is an oem stator
