Ok so I have a 1990 banshee and I'm going threw the carbs and my carb doesn't have a air screw spring or oring nor does it have a needle jet?!?! I'm follow the clymer manual and the one it shows is a bit different but wth. I'm doing the choke side so when I had it running it was blowing think smoke and oil out the left pipe is this the reason why??
Same get that can't figure out how to mix the oil. You should get far away from that thing.
Oh cmon, give him a small chance
  • Like 1
