Parting out my entire bike. I'm going to start from scratch... Again.. Anyways, I will list what I can think of off the top of my head. My bike is currently at my brothers, I will update the list by tomarrow if I forgot anything. Most stuff on the bike has about 10 hours on it. Great shape.
Protaper raptor rise in black-40
Asv f3 levers with asv perch and reservoir clamp black. 135
Ebay aluminum radiator with molded hoses. No leaks. Not beat up 75.
Omf rear beadlock rims. 9x9. Beautiful. 350 firm
Itp polished 10" fronts w/ smoothies. Barely used tires. Super clean. 150
+8 Tyson swingarm with 35mm carrier. Powdercoated tuxedo black. (ford color) 325
35mm pwk Airstrikers w/pods. 300
Chariot billet intake for 28-?. I did manage to cram 35mm carbs in it. 85?
Vf4. No broken pedals. Very nice. 135.
PD Coolhead. 21cc stroker domes (fast) Natural finish. 150
Full Hinson 8 plate clutch assembly. Basket, hub, pressure plate. Has newish driveline plates. 500?
Chariot pancake bearing. 15
65.5 stock cylinders. 10 hours on current bore. 795 pistons. Mild port job. I have no info on the port work. The bike ran good though. I'm not posting a price on these yet cuz I have not pulled my motor apart to check them. Motor is being pulled out tomarrow.
Fast lock out cover. Smoke lens. Very clean. 185.
Honda throttle with billet cap. 50
+2 braided brake lines. 40
+8 braided rear line. 30
Fox podium rear shock. 450lb spring. 200-225 lb rider for a +8. Very clean. Like new. 700.
Cpi head pipes only. Chrome is decent. 7-10. 175.
Frame is a 2000. Lightened and cleaned up. No ugly gussets anywhere. Gussets were replaced with chromoly tube. Chromoly lower subframe bars. 300. Painted tuxedo black.
Alba rear block off. Ano Blue. 10
alba front brake line clamps Ano blue.
15
Alba gas cap. Ano blue. 20.
Alba case saver. Ano blue. 20.
Alba intimidator front bumper with carbon insert. 75
Jds cdi relocation with matching KK drag cut harness. Has dirt bike style kill switch as well. 100.
My name is Moe. Text me at 7346427194 for more questions. I will list more things later and post better pics after hockey. Some stuff is Sandy from the dunes in the pictures. Everything is super clean
