i have one thats complete.  no top end pretty sure bottom end is stock  crank is toast.  500 + ship. no flywheel or stator
Yea I don't plan on cutting any of the plastic I hate the the way cut fenders look. As far as the motor kind of looking for a more complete set up with top and bottom end I can get a complete running motor for $1200 so I was just seeing if someone had one that was complete minus carbs that I could slowly rebuild
Where are you llocated?"sorry on my phone" I have a 89 motor that needs a rebuild. Has a hotrod crank cylinders have been ported. Shipping would be outragous im assuming, but maybe we can work somthing out if your interested.
Check out the for sale section. Frank the tank had a complete motor if I remember right.I Could be wrong.
sent from yo mammy house.
i am located in Warren mi about 4 miles north of Detroit
I have a ported 4mil that was a fresh build, pro design cool head, cut domes, runs on pump gas. Had an air leak, deto in left cylinder. Piston is junk, cylinder seems okay, crank bearing is suspect( I think I heard a little knock coming from bottom end)86c6b43bc4514c2773fb1af8fbf45542.jpg2c16a1653a515881afacbd4a756dbbe2.jpg
Sent from my VS985 4G using Tapatalk
