Triplecrown421 Posted August 27, 2015 Report Posted August 27, 2015 I bought a spare banshee motor the other day and when looking at it closely today I am suspicious that it is a rz/rd 350 motor. the crank cases are black and the side case is silver (opposite as my banshee motor) aswell there is an RPM hookup on the back of the crankcase. I have built blasters for years now an am familiar with the dt200s with them, I know gear ratios differ. im in the process of getting this rz350 motor running (using banshee cylinders) an am curious how different the gear ratios are then the banshee motor?? dos anyone here run rz bottom ends?? aswell could banshee transmission gears an clutch work in rz cases???? Quote
JKJK Posted August 27, 2015 Report Posted August 27, 2015 yes that's a rz bottom end.Most everything is compatible.The gear clusters are slightly taller+the shift forks should have actual roller tips. Quote
Triplecrown421 Posted August 28, 2015 Author Report Posted August 28, 2015 ok im going to use this motor for now in my banshee till my original motor is rebuilt. I know with the blaster an dt200 the gears are quite abit different, aswell the transmission shafts are thinner in the dts so the clutch an gears will not work in a blaster. just hoping that's not the case with the rz because I would like to use banshee gears in the bottom end of it in time cuz I imagin the gearing for the rz is abit far off for a quad?? Quote
JKJK Posted August 28, 2015 Report Posted August 28, 2015 you can just remove the two gear clusters as a assembly,and replace with your banshee gears.Leave the forks+drum if they are in good condition. Quote
