Hey guys, I recently just rebuilt basically my whole motor; I replaced the crank with the same 4 mil and this time I used the ultra stroker pistons (regular wiseco stroker.060 over) . It has a 4 mil vitos crank, .060 over ultra stroker pistons, trinity 2-1 carb (unknown jetting), ported and polished, larger radiator, new crank seals, cool heads with 22cc domes, k&n air filter, fmf gold series exhaust. I'm running 32:1 and using premium atf type f oil.
My problem is that it is not picking up power until high rims and when it does, the clutch slips real bad. The arrows are lighted up on the case and the fibers are only a little over a year old.
I'm open to any suggestions to making my build run any better than it is. Mainly on the jetting since I have never tuned it my self. Thanks guys! Sorry for the long post
Your using ATF fluid in your fuel?
There really is no set point for idle screw, any other time you would sync carbs with sync tool, but seems as you have a single carb, just set idle to where it idles good then play with your air screw
