bansheecaptain Posted August 12, 2015 Report Share Posted August 12, 2015 How much of the stock cover do you have to grind and where to install slingshot lock up. Quote Link to comment Share on other sites More sharing options...
Whitbread Posted August 12, 2015 Report Share Posted August 12, 2015 Just the 3 little nubs. Grind them just above flush with the rest of the inside of the cover. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted August 12, 2015 Report Share Posted August 12, 2015 Look inside the clutch cover where the exterior insert is mounted. There are three raised nubs where there are screws for mounting the insert. With the screws still installed, use a grinder, large drill bit, or small cutting device and knock the rounded tip off to make it flush with the rest of the inner casting. Pull the screws and put a dab of thread sealant or LOCTITE on them, and re install them. It's not much material really. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted August 12, 2015 Report Share Posted August 12, 2015 Well Matt, that was a bit more cut and dry then my drawn out dribble. Haha Quote Link to comment Share on other sites More sharing options...
