What gearing would be optimum for me, All input will be appreciated. My setup is 421 chettah Cub cleanup on cylinders Alky carbs stock chassis +8 arm I weigh 195lbs. Gearing now is 16-40 75RO 12 stags. The motor has plenty of power but it just doesn't seem as quick as it should be compared to similar builds. I haven't had it on the timed track yet just out Dune Drags. Thanks what is your opinions on gear choice
Did you measure the roll out or is that what was advertised when you bought the tires? You're gonna need about a 14/43 or 14/44 to run 300 ft assuming you have a 2-5 override.
If you're just grudge racing and going farther than 300' go with a 14/42.
jmo.
  • 3 weeks later...
Jmadd is on the money. You are geared pretty high with a 75" tire. With normal 72/73" 12 to 14 paddles you would be the same rear he recommended 43 or 44 and 15 front. With the bigger tires you want the 14 front for sure and a 43 to 46 rear.
