[email protected] Posted August 11, 2015 Report Posted August 11, 2015 Just about finished my banshee build, lacking a few parts......... intake , gas cap , radiator lines , chain.However one for the nerds here...... Can i get by , by bending the clutch arm down to get the clearance on the carb bowl........ Would jb weld work on the bottom ? or do i really just have to take it to a shop for welding.. Quote
special06shee Posted August 11, 2015 Report Posted August 11, 2015 Running pwk's? Is the drain nut hitting? If so grind the nut down as far as ya can. Just leave enough of the nut to get a wrench on it. Also, you can run reed spacers. If you go that route, id run them on the outside of reed cage. The spacers will give ya a little more wiggle room. But that would be my last route. 1 Quote
