I need a replacement set of the Noss head o-rings for a 72mm super cub. Do the super cub heads use the same o-rings as the regular cubs?
I have tried calling and emailing Noss but i can't get a hold of anyone there.
Of if anyone knows where i can get a set of the o-rings for 72mm bore i'd appreciate it.
Orings don't have to come from Noss. If you can measure your old ones or if someone knows what size they are you can get at a hardware store or online at MSC or Grainger. Just be sure to get Viton.
I've used 68 mm Cub orings in bigger bores before. There wasn't enough difference to matter on my particular motor. Don't know about the Super Cub.
  • 2 weeks later...
