gpr Posted August 8, 2015 Report Posted August 8, 2015 I need a replacement set of the Noss head o-rings for a 72mm super cub. Do the super cub heads use the same o-rings as the regular cubs? I have tried calling and emailing Noss but i can't get a hold of anyone there. Of if anyone knows where i can get a set of the o-rings for 72mm bore i'd appreciate it. Quote
gpr Posted August 10, 2015 Author Report Posted August 10, 2015 Bump, anyone know or know of a good way to get ahold of Noss? Quote
J-Madd Posted August 10, 2015 Report Posted August 10, 2015 Orings don't have to come from Noss. If you can measure your old ones or if someone knows what size they are you can get at a hardware store or online at MSC or Grainger. Just be sure to get Viton. I've used 68 mm Cub orings in bigger bores before. There wasn't enough difference to matter on my particular motor. Don't know about the Super Cub. Quote
Richard Dryden Posted August 22, 2015 Report Posted August 22, 2015 Why not just get them off EBAY? Chariot has them for $20. With copper washers. Quote
