Banshee_82 Posted August 4, 2015 Report Posted August 4, 2015 Having a little problem with my shee right now. I'll be riding for about 20-45 minutes then all a sudden it will start bogging out. This problem has happened last 3 rides. Keep changing plugs and that fixes the problem. But it's keeps on happening. Any ideas? Quote
Nightmare Posted August 4, 2015 Report Posted August 4, 2015 Are you fouling them? Are they soaked with oil? Quote
Banshee_82 Posted August 4, 2015 Author Report Posted August 4, 2015 I pulled out the plugs and one was dry and the other had oil on it. I wasn't in low enough rpm's, to foul them. Quote
Larry's Shee Posted August 4, 2015 Report Posted August 4, 2015 Which plug was oily? Might be time to good carb clean. Quote
Banshee_82 Posted August 4, 2015 Author Report Posted August 4, 2015 I just did a carb clean before I went out for a ride. Is there any reason why the plugs are fouling every ride? Keep on getting stuck in trails. Quote
sprinklerman Posted August 4, 2015 Report Posted August 4, 2015 I'd check plug caps with ohm meter. Sent from my SM-G900R4 using Tapatalk Quote
