Banshee_82
    1999 banshee
Banshee_82's Achievements
  1. I'll take a look at it. Mine seems to smoke a normal amount on each side, but just one side is too rich.
  2. I have been having a problem with my banshee when I'm riding it. It will run good for 25-45 minutes until it fouls a plug. It's will start to bog out and shut off. The right side, is the side that keeps fouling. I notices at the tip of the silencer, it is very black on the right side and and not on the left side. So I'm thinking the right side is too rich? Any ideas on the problem?
  3. I just did a carb clean before I went out for a ride. Is there any reason why the plugs are fouling every ride? Keep on getting stuck in trails.
  4. I pulled out the plugs and one was dry and the other had oil on it. I wasn't in low enough rpm's, to foul them.
  5. Having a little problem with my shee right now. I'll be riding for about 20-45 minutes then all a sudden it will start bogging out. This problem has happened last 3 rides. Keep changing plugs and that fixes the problem. But it's keeps on happening. Any ideas?
  6. No it should only have the one tube going between them. I had the same problem with my shee.
  7. I never heard of that ever.
  8. It's a more well know company in canada. I only put 5 hours on it and the first time I rode it was A lot more powerful.
  9. Powerfist. Held throttle wide open and that's what I got.
  10. Recently I just fix my banshee. It wasn't starting. I was messing around with carbs and got it going . I got two problems though. It doesn't want to idle, I notice it has less throttle response and is running weaker then it did before. Did a compression test and it is running at 105 on one side and 110 on the other .
  11. Got it running! It seems to feel weak and it's not pulling hard like it used to. Doesn't want to idle ether.
  12. The tip of the compression tester isn't as long as the spark plug. I was told that leaving in one spark plug and holding the throttle wide open is how you should test it. The brand of the compression tester is powerfist.
  13. Only 100psi in each cylinder. Needs top end. Would that cause it from not starting
  14. I'm picking up a compression tester right now
