TurnerBanshee Posted July 12, 2015 Report Posted July 12, 2015 My OEM ignition coil these were damaged, I replaced these for one that I had saved for parts of another engine (I think bullshit), because the banshee now has: slow start, sometimes cutting out, the ignition coil that put the mechanic I think is similar or complete chinese parts the mechanic said that don't matter what kind of ignition coil are, all do same work but I think that this guy it is wrong because my banshee when had the oem ignition coil, don't have a lot problem for start, almost ever first kick. now, the banshee start at first kick and immediately shut off (sometimes) so needs 10 kicks with choke for start again after first kick, sometimes starts at first kick without problem before don't had all those problems the question is? really a ignition coil affects the performance of machine of only my wrong idea? if previous question it true, can I get better ignition coil that OEM for best performance? or the oem ignition coil is the only way for better performance, for example I would like for running (top end I guess) Quote
Larry's Shee Posted July 13, 2015 Report Posted July 13, 2015 Grammer nazis be all over that shit. Get a manual and start ohming everything. Replace Chiwanese shit. Quote
