sixstringninja024 Posted July 12, 2015 Report Posted July 12, 2015 I just got finished putting my banshee back together after having the frame powder coated. It cranked right up and ran good for a few minutes, but when I went to shut it off it just kept on running. I don't have a key I just turned the switch off. Anybody know what would cause this? Quote
sixstringninja024 Posted July 12, 2015 Author Report Posted July 12, 2015 How do I ground the kill switch? I ground the coating off under voltage regulator, under the coil, and grounded motor to frame. Quote
hoppedupandcutdown Posted July 12, 2015 Report Posted July 12, 2015 check for broken wire then. The black wire out of the CDI has to be grounded, so when the White/black wire from the kill switch grounds the bike will shut off. Or, black to white/black = no run 1 Quote
hoppedupandcutdown Posted July 12, 2015 Report Posted July 12, 2015 I just remember DDQ had his black wire broke in the harness and even touching the White/black to the engine wouldn't kill it. so his deadman would not work no matter what. Camatv figured it and fixed it all up for him last Sept. at LSOK - FTMFW Quote
hoppedupandcutdown Posted July 12, 2015 Report Posted July 12, 2015 r/b to b= no run main switch b/w to b= no run engine stop switch or y/b to b= no run carb and throttle switches if ya got tors still page 218 in the banshee bible if i remember correctly i might add that this is for 2001 and older I though it was the Red/black to Black for it to run? Quote
sixstringninja024 Posted July 12, 2015 Author Report Posted July 12, 2015 I don't know much about this electrical shit. I just plugged everything back the way it was when it last ran. I'm gonna have to brush up on some of this stuff. The tors is gone but the connector to the tors module is still connected to the harness. I did chop off the tors carb connectors though. Could that have anything to do with it? Quote
hoppedupandcutdown Posted July 12, 2015 Report Posted July 12, 2015 If you mean that the module is still plugged in, unplug it. As long as no TORS wires are grounding (touching) all should be good. Should still strip ALL that crap out. Quote
sixstringninja024 Posted July 12, 2015 Author Report Posted July 12, 2015 (edited) No the module is not plugged in. It's in the garbage. All that's left is the connector that goes from the harness to the tors control module connector. I will take a closer look at all the tors wires tomorrow to make sure none of the wires are grounding. Thanks for the info so far. Edited July 12, 2015 by sixstringninja024 Quote
hoppedupandcutdown Posted July 12, 2015 Report Posted July 12, 2015 kill switch can be bad too, just unplug it and try that. Quote
