BamBam6942 Posted July 12, 2015 Report Posted July 12, 2015 (edited) I recently bought a banshee and just rebuilt the top end ( stock cylinders). The previous owner added a fmf pipe and and a trinity 2-1 carb set up. Ok here's my problem ,,,,fired it up after rebuild and did a heat cycle ,,,,,, everything sounded fine and ran fine , maybe a little rich idling but nothing out of the norm. Went to do second heat cycle ,,,, And the shee died 3-4 min into. Fired right back up but then I got to looking around , I noticed the the left side exhaust was hot ( normal). But the right side was barely warm ,,,,,,normally I would think it was the carbs ,,, but since I have the 2-1 ,,,, I don't think that's it. Any suggestions ?? Edited July 12, 2015 by BamBam6942 Quote
BamBam6942 Posted July 12, 2015 Author Report Posted July 12, 2015 Only thing I can think is maybe the reeds ?? Quote
Larry's Shee Posted July 13, 2015 Report Posted July 13, 2015 Or an air leak on that side Did you do a leak test aftr assembly? Quote
boarder8135 Posted July 19, 2015 Report Posted July 19, 2015 idk if you have the same exact problem, but I ended up messing up my coil for my spark plugs since it wasn't grounded well. This caused only one side to work and I had the same temp issue where one side was cold and one was normal temp Quote
fastbanshee8 Posted July 19, 2015 Report Posted July 19, 2015 Check the pick-up gap on your flywheel, .018-.020. A business card works good, or feeler gauges. Take the spark plug boots off, and cut the wires back about a 1/4". Put new plug boots on. Quote
