Shaun Amori Shawna Posted June 29, 2015 Report Posted June 29, 2015 I blew two stator side bearings. You guys it's my stator side case out of around making them to blow. Thanks guys Quote
Larry's Shee Posted June 29, 2015 Report Posted June 29, 2015 Do you know for a fact that you have matching cases? What brand bearing are you useing? Chingchong Chewey? Quote
sleeper06 Posted June 29, 2015 Report Posted June 29, 2015 Or same air leak, same carb . Pressure test before tear down allways, otherwise your guessing like you are now Quote
Shaun Amori Shawna Posted July 1, 2015 Author Report Posted July 1, 2015 No the CRANK not fucked up. Its a 4mil crank. The case are to different cases. I did leak down test before and had no problem. The bearing is ALL BALLS BEARING. THANKS GUYS. Quote
Rigid_Banshee Posted July 1, 2015 Report Posted July 1, 2015 All Balls should be Koyo, there made in Japan... There definitely NOT cheap bearings. You sure your cranks true ? Used or brand new ? Quote
Shaun Amori Shawna Posted July 1, 2015 Author Report Posted July 1, 2015 CRANK was a new hotrod 4mill crank Quote
Larry's Shee Posted July 2, 2015 Report Posted July 2, 2015 Way I see it you have two choices. Have crank inspected or have cases inspected by something a little more precise than the eye. Quote
