Ok I had the topic a while back about it well I figured out the problem and all it was, was the whole clutch system was messed up well I put a new clutch actuator in the motor that pushes the flywheel out and put it all together and kicked it a few times and it tried to fire then it wouldny do nuttin and by nuttin I mean absolutely zilch but it has no fire on either plug and it's already had a tors delete and all what could be the problem or what could I check?
Check ground connections. Make sure key/kill switch are working properly.
New plugs.
You can pull boot off of coil wire and cut off 1/4 inch of wire to expose some clean wire and re install boot.
Set pick up gap.019
Clean stator poles and flywheel
Ohm stator
Swap cdi with a known good one
If you have money to burn, give it to me and I'll come ohm that shit out.
Really tho, can get an ohm meter under $20, and go at it. Everything can be checked but the CDI
All the specs are somewhere on the forum, or in a Clymers manual.
ZCould be something as simple as a bad ground or you forgot to turn thg switch on.
Haha well the switch was on and it's had a key switch delete and the tors delete it run good before so Idk what happened I believed the stator or coil went out and what I seen and checked a oem stator is 545 bucks
