banshee runs fine except around 3/4 throttle to full throttle sputters and blows flames out exhaust
I ot a 4 mil banshee, 68 mm pistons, 39 mm carbs, 19 cc domes I think,v force 4 reeds, and the port job looks home made and scp drag pipes.  it runs fine until u get to around 3/4 throttle to full throttle and it sputters and spits flames out of exhaust, ive tried richn up the main jet and its the same and leaned it out and wont really rev out when I leaned it.  any ideas on what it could be, maybe electrical or the port job on it
couldn't tell u if the stator was stock or not, put timing back to 0 its still the same, ive went all they way to 185 on main and no change really and went all the way to 140 on main and didn't want to rev out with 140 but 150 - 185 its really no change
sorry for late reply but I pressured it up to 7 psi and let it set around 8 mins and it leaked around .5 psi, ive cked stator, coils,  and tried jetting evry way and just cant get it to not throw blue flames and cut out a bit at full throttle
What groove are the needle clips on?
What are your current jets?
What elevation and temp is your riding location?
What octane fuel and what brand oil/ratio are you using?
Have you done a compression test?
