When performing a compression test, it is always said to have WOT.  My question is, since the carbs are off already, can I perform a compression test then?  I am not sure if there is a particular reason to hold WOT or just because it takes extra time to remove the carbs or because you will get a more "real time" result holding WOT or could it cause damage?
