SHEEMAN0415 Posted May 12, 2015 Report Posted May 12, 2015 1) What type of aftermarket exhaust do you have? Full Shearer exhaust2) What type of airfilter do you have?K&N pod3) Are you a)running a stock airbox with lid stock airbox with NO lid c) Stock airbox with vents d) no airbox at allstock airbox with vents4) What is your elevation? (If you don't know, go here: http://www.topozone.com )356 feet5) What size pilot jets are you using?306) What size main jets are you using?3207) What temperature is your Banshee jetted for?roughly 65-708) Do you have a port job?no9) What kind of carbs?stock10) What size carbs? stock Does this seem right to you guys? I bought it with these jets. I put brand new top end in and it ran awesome. I parked it one night and now it doesn't wanna idle and as soon as i hit the gas it bogs out and dies. Is the pilot too big? Just weird cause it ran and idled fine one day then the next that happened Quote
SHEEMAN0415 Posted May 12, 2015 Author Report Posted May 12, 2015 Yup! Sent from my iPhone using Tapatalk Quote
98_sheester Posted May 12, 2015 Report Posted May 12, 2015 Did you change your idle at all. Maybe a clogged pilot Quote
SHEEMAN0415 Posted May 12, 2015 Author Report Posted May 12, 2015 Thats ehat i thought. Does a 30 seem to big to you? Sent from my iPhone using Tapatalk Quote
98_sheester Posted May 12, 2015 Report Posted May 12, 2015 They might be a little big but i have some 27.5s if you wanna try them Quote
SHEEMAN0415 Posted May 12, 2015 Author Report Posted May 12, 2015 There uh boyesen reeds and cages Sent from my iPhone using Tapatalk Quote
98_sheester Posted May 12, 2015 Report Posted May 12, 2015 Yeah 27.5s should be fine i have boysen with the rad valve and run mine with 27.5 Quote
oldskool Posted May 12, 2015 Report Posted May 12, 2015 Try some new plugs. 320 main seems large for a 350 motor with no porting. I would think around 290 at sea level, maybe less. Quote
SHEEMAN0415 Posted May 13, 2015 Author Report Posted May 13, 2015 Sorry guys busy day. So im at 356 feet aabove sea level. You guys think i should drop a pilot size and try like 290 mains? Sent from my iPhone using Tapatalk Quote
SHEEMAN0415 Posted May 13, 2015 Author Report Posted May 13, 2015 sounds good ill give it a shot. thanks guys! Quote
lowidenfast Posted May 13, 2015 Report Posted May 13, 2015 I have a stock motor with no port work, T5 pipes, K&N pods (no air box) and VF4 reeds at ~800 ft elevation and run 27.5 pilots with 300 mains. 300 mains still seems a tad rich, I could probably run 290's so 30 pilots + 320 mains def. seems rich especially with an air box Quote
